1962 Uni Help Quick!
Old Aug 13, 2007 | 02:35 PM
62 uni wannabe's Avatar
62 uni wannabe
Hi,
I'm new to this forum and want to say hi and congratulate you guys on a great site. I am a member of the corvette forum and have 1971 and 2000 convertibles but I still like my big Excursion when I have to "git er done". I am in need of some quick help on pricing etc. I ran into a 1962 uni (that's why I picked my log in). Supposedly it has 27,000 original miles. It's red and white, 292 ci 3sp on column with no rust. I'm told these are the options it has.... headliner, deluxe wheel covers, map pockets, chrome bumpers, tow hitch. It look real nice and I go to drive it and crawl around under it tomorrow. Any quick tips on trouble points to look for? Any rough estimate of value? Where would I find the vin# and what could it tell me?
Thanks in advance for your help and I hope I'll be able to report back with some good news.
Mike
Old Aug 13, 2007 | 03:45 PM
garbz2's Avatar
garbz2
27K
If so it should be 100 point quality and way pricey.
The vin on a 62 is located on the glove box door. also on the frame rail top alongside the shock tower.
Places to look for rust are the torque box and lower front a pillars below the hinges. Also a problem are is behind the gas tank where the rear panel meets the bed floor.
Garbz
Old Aug 13, 2007 | 04:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 62 uni wannabe
Hi,
Mike
Welcome to FTE
No deluxe wheel covers were offered on Ford pickups till 1966. Whatever you have was prolly dealer installed. Like the wheelcovers, the tow hitch was available only over the parts counter.
Post all the info from the Rating (VIN) Plate. The codes, when decoded, will tell you among other things: the type of engine, transmission, rear axle and ratio, what the original color(s) are, type of interior fabrics used, where the truck was assembled, and what area in the US (or Canada) it was ordered from and sent to. The actual build month will also be known.
One of us here on FTE will ID what the wheelcovers are and inform you what they were used on.
Old Aug 14, 2007 | 07:26 AM
62 uni wannabe
Thanks
Thanks for the fast response everyone. I called to set up time to view and asked for vin tag info.
F10CG32002
WB 114
COLOR JM
MODEL F100
TRANS A
AXLE 11
GVW 5000
HP 135
RPM 3800
I'll check for overall running condition/rust areas and report back tomorrow with the sellers bottom price for your comments.
Old Aug 14, 2007 | 08:19 AM
NumberDummy
F10CG32002
WB 114
COLOR JM
MODEL F100
TRANS A
AXLE 11
GVW 5000
HP 135
RPM 3800
F10 = F100 2WD
C = 292 2V
G = Chicago, IL Ford Assemby Plant
32002 = missing a digit-should be 6.
114" Wheelbase
J = Monte Carlo Red
M = Corinthian White
F100 = F100 2WD / 5000 lbs. GVWR
A = Ford 3 Speed Manual
11 = Ford 9 Inch / WBG / 3.70-1 / NON Limited Slip / 3300 lb. Rear Axle Capacity
GVWR 5,000 lbs.
135 HP @ 3800 RPM
You missed the DSO number. That will tell where the truck was ordered from.
Old Aug 14, 2007 | 12:33 PM
magee's Avatar
magee
Another common trouble spot is the radiator core support. Particularly around the battery at the bottom. The acid does a number on 'em in that area.
Old Aug 14, 2007 | 12:50 PM
cobraguy's Avatar
cobraguy
Sorry magee the battery is on the firewall passenger side. But the core support is still a trouble spot. Look behind the seat and under the fuel tank. take a small flashlight maybe even a small mirror. Tailgates are always rotten in the end boxes and around the hinge points. The cap of the cab along the top of the drip rails. Bottom corners of the windshield frame. Bottom af the pillar where the lower door hinge is. If there is a little rust at the front of the step box right under the lower hinge everything behind it will be rotten. Basically every lower corner on these things collect moisture and eventually rust. Cab supports are another trouble spot. Not the arms that extend from the frame but the builtup sections of the body that the bolts go through.
Old Aug 14, 2007 | 12:54 PM
magee's Avatar
magee
Dang it! I was thinking about my 66.
Hoss591's Avatar
Hoss591
hi i'm new too and dumb..where the heck is the post new tread button?
Old Aug 14, 2007 | 02:08 PM
magee's Avatar
magee
To post a new thread, go to the forum you want to post in and next to the page count and above the list of current threads is a "new topic" button.
Welcome aboard! There is a wealth of information here.
Old Aug 14, 2007 | 02:09 PM
cobraguy's Avatar
cobraguy
Hoss you go back to the forum menu (1 back click). There is a blue bubble says New Topic at the top of the column. Welcome to FTE, Rich.
kjvforme
1961 - 1963 F100 Unibody
Sep 10, 2013 11:23 AM
1962 Uni
Jul 12, 2013 04:04 PM
1962 Uni
N. California Chapter
Jun 20, 2013 03:14 PM
fordman67
Sep 8, 2011 01:41 AM
Scavenger
Mar 11, 2002 12:26 AM
