My AC gets cold but...
Old Aug 11, 2007 | 12:36 PM
crosbo's Avatar
crosbo
...but only at speed. The compressor also does not seem to cycle. Last evening after returning from a trip, I left the rig running with the AC on and cool, but the compressor never cycled. The lines at the dryer were cool and covered with condensation, as was the back of the compressor where the low pressure line enters, but the compressor never cycled.
Ideas? Am I still a little low on freon?
Old Aug 11, 2007 | 01:07 PM
John311t's Avatar
John311t
If i understand you correctly, its only cold when you are moving, when stopped it gets warm? Check to be sure your radiator and all your coolers in the front are clean between the fins, my truck did the same thing, it would only be cold while moving, after i cleaned out my radiator, intercooler, and sprayed out the condensor its cold all the time.
Old Aug 11, 2007 | 01:28 PM
crosbo's Avatar
crosbo
Thanx for the suggestion John. Nope all is clean. I meticulously cleaned all...as well as spent a couple hours or more straightening every bent fin...yeah, I'm a bit obsessive/compulsive.
I'm thinking I'll pick up one more can of 134 today, and give it a try.
Old Aug 11, 2007 | 03:40 PM
Poohbear's Avatar
Poohbear
If the low pressure line is condensating all the way to the compressor I would say your 134a charge is close to being right.
Old Aug 11, 2007 | 05:17 PM
crosbo's Avatar
crosbo
Thanx Pooh...must have been, cause now a can later, the compressor is kicking on/off, on/off nonstop. I think I've gone too far and have overcharged.
Old Aug 11, 2007 | 05:43 PM
medhvac's Avatar
medhvac
if its cycling on and off your gettin close to ur charge u may need to add more!
Old Aug 11, 2007 | 06:26 PM
crosbo's Avatar
crosbo
Thanx Med, but I think I reached a point of overcharging...the low-side gauge reached west of 70lbs and suddenly things weren't cooling any longer. I think I reached a limit where the "safety factor" was kicking in and releasing the clutch, then as soon as the pressure dropped below the "high limit", the clutch was engaging again. I think...
scorpion48
Apr 30, 2012 03:24 PM
ngng
Oct 2, 2009 11:22 AM
Aerocook
Aerostar
17
Jul 10, 2008 09:58 AM
sail2244
Aug 30, 2003 09:21 PM
fcarruth
1978 - 1996 Big Bronco
Jul 19, 2003 01:12 AM
