crew cab rear window?
Old Aug 10, 2007 | 10:25 PM
cant remember's Avatar
cant remember
hello wondering if anybody knows if the rear doors use the same regulator as the front? if they are different, anybody know of a place that sells them? thanks D.J.
Old Aug 10, 2007 | 10:35 PM
Mil1ion's Avatar
Mil1ion
I would say no because the glass is a different size .....so the regulator arm would be shorter.
Maybe I'll check my book to see for sure.
Old Aug 10, 2007 | 11:29 PM
cant remember
well i was told the weather stripping was the same front too rear, so i would asume the window is the same size. but the door itself is not at wide as the front.
Old Aug 11, 2007 | 04:32 AM
LTAR's Avatar
LTAR
Will let you know tonight when
I go home and look at mine, but I am pretty sure the glass is the same but the regulators and track on the bottom of the glass are different. Afraid I dont have a spare but you might try posting a message at: http://autos.groups.yahoo.com/group/FordCrewCab61-79/
Also look in the clasified listings here: https://www.ford-trucks.com/classifi...cat.php/cat/17
You may have to look back aways but I think someone had some doors and parts for crew cabs.
Mark
Old Aug 11, 2007 | 08:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation Crew Cab Window Regulators/Window Rollers
D3TZ-2527000-A .. Right Rear Window Regulator
D3TZ-2527001-A .. Left Rear Window Regulator
C8SZ-57262A32-A .. Window Roller
Regulators fit 1973/79 rear door Crew Cabs only.
Is the regulator bad, or just the window roller?
Remember, rear window regulators aren't used much, so will usually be stiff.
White lithium grease usually solves stiff window mechanisms.
Ford window rollers = known to fail. If the regulator doesn't work, or the window has fallen down into the door, the fault usually lies with the roller.
Crew Cab rear door window rollers (C8SZ-57262A32-A) are the same as:
Front Door: 1968/72 LTD; T-Bird; Maverick 2dr; Falcon. 1968/72 Mercury Marquis; Mark III & IV; Comet.
Front Door: 1968/71 Fairlane/Torino & MUSTANG. 1968/71 Montego & Cougar
Rear Door: 1973/78 LTD/Mercury Marquis
Quarter Window: 1973/76 T-Bird; Mark IV.
Old Aug 11, 2007 | 11:41 AM
cant remember
alright thanks again guys for the great info. the driver side rear window handle just spins without any window movoment. i havent pulled the rear door panels yet. just looking for info. i am waiting for all the new weather stripping to get here. thanks again DJ
Old Aug 11, 2007 | 03:55 PM
NumberDummy
The plastic window roller has a stud (which pivots) pressed into it.
The stud is bolted to the end of the window regulator arm.
The roller portion fits into the window channel.
The stud breaks off the window roller.
The window handle spins freely.
Very Common.
Old Aug 11, 2007 | 04:36 PM
cant remember
well there i go thanks a bunch. ND
also ND i called that # u gave me for the AC vents there locator computer has been down for 2 weeks and no luck they gave me a bunch of other numbers to call and no go so used is the only way
again thanks for all the info guys
Sweetpea02
May 7, 2013 08:25 PM
foreverfordtrucks
Jul 8, 2010 05:51 PM
mitch1500
Jun 22, 2010 08:21 PM
BobbyFord
Apr 10, 2007 08:43 PM
