Sponsored by: Real Truck
Truck Stalls
Old Aug 10, 2007 | 03:49 PM
engmfg1's Avatar
engmfg1
Truck Stalls
I have a 2000 F250 4x4 with V10, the truck will start and stay idle in park and in neutral, as soon as I put it in drive it stalls, it seems to be fine in reveres<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Aug 10, 2007 | 04:57 PM
bpounds's Avatar
bpounds
Maybe your torque converter is not unlocking?
Hey, we're almost neighbors. I'm in Whittier.
Bill
Old Aug 11, 2007 | 06:37 PM
catmacanic's Avatar
catmacanic
My sons F250 4X4 diesel started doing the same thing, take your foot of the brake put in gear ,lug engine & take off to about 10mph unlock and drive normal, then started doing it only in reverse. I tested it and thinking its a sticking valve. He had been towing his jeep and got trans hot ,blow some oil out,It fixed its self after he refilled trans .engine running and in park hot oil .Well see if it stays fixed.
Somebody ealse has a post on same problem but can,t find it.
Old Aug 13, 2007 | 08:38 AM
engmfg1's Avatar
engmfg1
truck stalls
Bill, what are you talking about man! we are neighbors i grow up in Pico Rivera, anyhow just got back in town and i will check all this today thanks you guys for help.
Eric,
Old Aug 13, 2007 | 09:20 AM
bpounds's Avatar
bpounds
Catmac has a good point. If you can get it rolling enough so that when you throw it in gear it won't kill it, then you could run it up to temp and shift through the gears including a couple of lockup cycles, it might free itself. But around this town I don't know if you can find enough real estate to do that. You could try jacking the rear axle up too, just to let you get it in gear without killing it. I think I've read that the lockup is solenoid actuated and they can stick. It's probably not an expensive problem.
See you around town,
Bill
Old Aug 13, 2007 | 06:11 PM
zx250's Avatar
zx250
Of the next Riffraff East
Have also heard of a wire under the steering wheel cover chaffing and shorting out when shift lever is moved. Does it sound like it is loading up and dieing or just turning off?
