Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
I need A/C
Old Aug 20, 2007 | 04:51 AM
  #31
Crash687's Avatar
Crash687
Originally Posted by Peter94
Would it also be possible to install such a capacitor on my air compressor? To aid in starting at the 120 cut in pressure? Then most of my garage electricity problems would be solved! thanks a lot!
If it has just a run capacitor on the motor(I don't see why not), some air compressor motors also have start capacitors. Capacitors (run or start) are under those humps on the otter case of the motor.
If you have trouble starting the compressor, you may have a bad unloader (Does the compressor bleed off when it cycles off?) or you could try lowering your cut in pressure to 100 psi.
mustang_gt_350
44
Mar 11, 2013 03:19 PM
jlmotox
Apr 3, 2011 02:33 PM
oldcoupe42
Garage & Workshop
23
Nov 23, 2005 08:58 AM
rscritch
Garage & Workshop
52
Jun 1, 2004 12:35 PM
FORDBOY357
Garage & Workshop
16
Oct 2, 2002 12:26 AM
