Engine Code Problem
Old Aug 9, 2007 | 10:30 PM
beastieboy's Avatar
beastieboy
Engine Code Problem
I own a 1991 F250/460/Auto/105K.
Here is my problem. I am pulling engine codes for a bad TPS and EGR. I took it to a reputable service shop and they tested those parts and they were functioning correctly. They reset the computer and It pulled the same codes again after 100 miles. The Check Engine light came on once within that 100 miles for only a few miles then went off. The truck seems to run just fine except for a mild up shift in the tranny while letting off the throttle to coast. It's not slipping but a very subtle up shift before it drops into the next lower gear. The Tranny is freshly rebuilt. Any ideas??
Old Aug 10, 2007 | 07:40 AM
projectSHO89's Avatar
projectSHO89
Post the exact DTCs.
Old Aug 10, 2007 | 08:30 AM
Franklin2's Avatar
Franklin2
If you want to start pulling the codes yourself, here's a link to tell you how to do it and you can use a simple meter with a needle or a testlight.
http://www.fordfuelinjection.com/?p=13
Old Aug 16, 2007 | 05:04 PM
beastieboy's Avatar
beastieboy
Here is what the tech wrote down:
32- EGR low signal
41- EGO Not switching-Lean Bank 1
63- TPS signal to low
Old Aug 16, 2007 | 10:16 PM
Franklin2's Avatar
Franklin2
I would check the wiring very carefully to these components. If it's not too expensive, you might want to go ahead and replace the TPS sensor.
