6.0 smells like fish!
Old Aug 9, 2007 | 04:26 PM
elkarcher's Avatar
elkarcher
Hey guys, I have been noticing a strange smell coming into the cab when I have my engine under a load. The only way to explain it is it smells alot like fish. I am a fisherman and no there are no fish anywhere in my truck. I even made my wife get out to see if it fixed the problem.(J.K) Now that all of the jokes are out of the way, does anyone have any ideas?
elkarcher
Old Aug 9, 2007 | 04:38 PM
Kep4's Avatar
Kep4
Jäger
Have you checked around the degas bottle for puked coolant? That doesn't smell like fish to me but we all have our own opinions on things. Either that or a Bass swam into the intake housing... got any buddies with a practical joke style sense of humor?
BTW, Better hope your wife doesn't see this thread... hide the guns, knives, baseball bats, etc.. RIGHT NOW!!
Old Aug 9, 2007 | 04:44 PM
elkarcher's Avatar
elkarcher
where do I find the degas bottle?
Old Aug 9, 2007 | 04:48 PM
Kep4's Avatar
Kep4
Jäger
It's the coolant bottle under the hood, driver's side, it's opaque plastic with a black plastic top and black screw-on cap. Do you see any tan looking powdery substance around the cap? That would be puked coolant.
Old Aug 9, 2007 | 05:20 PM
elkarcher's Avatar
elkarcher
Kelpler4, I checked the degas bottle and there was puked coolant around the top. I smelled it and it is the same smell coming into the cab. Any fixes?
Thanks for the help!
Elkarcher
Old Aug 9, 2007 | 05:29 PM
Storm's Avatar
Storm
Are you running a tuner? The puking will be either the heads lifted from high cylinder compression or an EGR cooler failure..
Old Aug 9, 2007 | 05:32 PM
Kep4's Avatar
Kep4
Jäger
One of the resident Tech's will hopefully chime in on this with a more educated answer. Prior to that:
  1. Make sure the coolant level is correct, the factory 'Full' level is too high, there was a TSB on this for 05 PSD's to lower the coolant to the 'Low' level and they added a sticker reflecting this.
  2. Clean the cap and bottle threads and tighten the cap down.
Mine has burped coolant when stock and otherwise. It's apparently caused by the EGR boiling the coolant and the rapid expansion of gasses forces coolant out the degas bottle cap.
Old Aug 9, 2007 | 05:43 PM
elkarcher's Avatar
elkarcher
Thanks for the help guys. The truck is completely stock with 35k miles on it. There is only a very small amount of coolant around the lid of the degas bottle and I have never seen any leaking coolant or anything anywhere else. With the small amount i've got on the bottle, does it mean that there is definatley a problem with lifted heads, egr or anything else? Can you lift heads with a stock truck?
Old Aug 9, 2007 | 05:47 PM
Storm's Avatar
Storm
Yes it is possible to lift the heads stock.. Did you check around the area, Airbox, harnesses, Exhaust manifold for coolant.. Problem I see is if there is only a little bit around the lid, that shouldn't be enough to heat and smell.. Is your A/C running at all when you smell it?
Old Aug 9, 2007 | 05:48 PM
Kep4's Avatar
Kep4
Jäger
Mine puffed coolant at 3,000 miles, bone stock, when towing over the Grapevine Grade in Kali. It's puked four times since then (34,800 miles now), all when towing over the Grapevine in summertime.
Can't say for sure you've lifted the heads, more likely an EGR issue, maybe just a heavy load and the coolant boiled in the EGR cooler.
Old Aug 9, 2007 | 05:57 PM
elkarcher's Avatar
elkarcher
If I remember right, we were smelling it with the air on or off. I will have to look around and see if I can find anymore anywhere else. Do you think this is something I should take it to the dealer for or am I jumping the gun? I was so nervous when I bought the truck that now anytime anything happens, I automatically go into "oh sh** mode".
Old Aug 9, 2007 | 05:59 PM
Storm's Avatar
Storm
No take it in for sure.. Let me them know and check it.. First stage will be checking the EGR Cooler for failure.. Then they will move to the heads.. It is quite possible stretch the heads stock with a load.. The factory studs are a common part that fails.. It's been documented time and time again..
Old Aug 9, 2007 | 06:07 PM
elkarcher's Avatar
elkarcher
Guess i'm callin the dealer. Thanks again for all of your help guys! Will post back with results.
Elkarcher
Old Aug 9, 2007 | 06:28 PM
msgtg's Avatar
msgtg
In the mean time....do you remember what your coolant level was in the bottle? The reason I'm asking is there have been several guys who had puking issues until they simply lowered the level in the degas bottle to just below the minimum mark. Once they did that, they quit having issues.
Good Luck and let us know how it turns out!
Joe
Old Aug 9, 2007 | 07:15 PM
elkarcher's Avatar
elkarcher
The coolant level was just about full. I read Kepler4's reply that mentions the coolant level problem and I think I will lower the level and see if it happens again. I will try that befour I check the truck into the clinic for who knows how long.
