Dyno numbers on 05+ V10?
223hp and 316ft/lb??? That's what a 5.4 will put down. I have a 5k lb boat that I tow in Denver and up the mountains, and my 5.4 absolutely struggles. I was hoping a new V10 would take care of it, and also give me the opportunity to get a 5th wheel. Definitely don't want to go diesel. I'm thinking maybe their numbers are wrong?
Thanks!
I think they results are skewed for no less than two reasons.
1. It was done by a diesel magazine which had no intentions of a fair test.
2. The numbers were RPM Limited?? What the hell is that? Maybe their dyno couldn't support more revs. But it was certainly below the advertised HP peak of the V10.
I didn't read the entire test simply because what I did read didn't pan out with what other, more credible, tests have shown.
Thanks!
The numbers are around here somewhere, but those you quoted do sound low to me.
Forget the numbers...ask the guys who actually use their V-10's...shucks, I just drive mine around like a passenger car....so far.
I like how all the Diesel mags that test the 6.4l get no less than 16mpg empty. Go down to the 6.4l forum and you will see those guys aren't getting close to 16mpg let alone 19mpg.
"The V-10 tester had 4.30 gears (4.10s are standard), and the diesel is only available with a 3.73 ratio, but as the acceleration runs proved, the gas truck was still at a disadvantage while launching."
They no doubt Powerbraked the 6.4l to spool up the Turbos to launch.
Take what magazines say with a grain of salt.
when I researched which I wanted the 6.0 or 6.8 I ran all those numbers. The numbers they pulled out of their a$$ comparing diesel over gas is a joke. When I bought mine diesel was cheaper now its more than gas. If they did a the simple math equation....that the diesel gets 4 more miles per gallon......wipeeeee!!!!
divide that into 12,000 mile per average year.... at the same cost $3 per gallon.....my calculation has $2,400 for diesel and $3,270 for gas per year......at $870 savings just from the better milage it would take 7+ years to break even on the $6,295 for the diesel.
well at 7+ years before you break even......then 12K X 7 = 84,000 miles of driving and doing tune ups....
Then add in the cost for the 3,000 mile tune ups. Mine is less than $50, my camping buddy spends $120+ ........gas wins again, because he'll spend an extra $1,960 in tuneup costs in that 7 years......
As for the comparing towing....my 4.30 can tow as much as the diesel 15,500 lbs. And how often do you race a diesel off a dead stop? they act as if that happens everyday!!!!
HA I'm so glad I did the right math not that FUZZY math!!!!!
I think something many people overlook too if there financing is the extra interest with the diesel. $6300 more for the diesel over the V10 and factor in all the extra interest you pay on the $6300, plus the extra tax throughout the length of the loan. It can add up.
I saw a new Reg Cab F-350 XL 4X4 6.4l Auto stripped down model for $38,500. Friggin Nuts in my book.
I'd like to see them do an acceleration test on a wet road. With the extra weight on the front of the diesel along with the torque you'll have a hard time getting traction.
They get ya comin' and goin'!!
The F150's 5.4 has a 4R70W (or 4R75W?) tranny - lighter internals than the TorqShift 5-speed. Driveshaft is heavier. Crankshaft is heavier. Rear end gear is heavier, heavier axles, wheels, everything.
All that extra weight means a chassis dyno will see lower numbers.
There is more to the F150 and F250/F350 issue. You have to remember you're buying a much heavier/stouter truck when you buy the F250/F350. The horsepower/torque of the V10 is there, whether the magazines agree or not (ask an owner). You can tow/haul more with the F250/F350, but the difference may not seem as dramatic as you might think if you're used to driving a lighter vehicle. There are plenty of stock "rally" type vehicles that have far less horsepower/torque than my V10, but I know I can't outrun them. I can certainly put a couple or more on a trailer and haul them up and down the mountains around here, which they wouldn't be able to do. My F250 will likely last longer doing that job too, longer than a lighter truck asked to do the same work.
Another thing to remember is that the tests need to be based on the vehicle, not just one vehicle. I didn't read the article, but I would imagine the diesel has significantly more power at lower RPMs. If they didn't wind up the V10 a little then they were missing out of the peak hp/torque and weren't testing based on the specific vehicle on the dyno. I don't know, but I'd say if you're looking for a 5th wheel someday you'll want a diesel (which you've already said you don't), or the V10. The V10 will struggle more at elevation though, because it doesn't have the turbo or forced air, so remember that.
From what I've heard and read, everyone seems more than happy towing with their v10, although maybe not at 6% grades at 8000 feet. All I know is my F150 is at first gear redline towing my boat up Eisenhower, and I'm just waiting for something to give....
Dyno Test
Scott Clark and the staff at Spectre Performance hooked both of our F-250 extended cab trucks to their Mustang MD-1750 load dyno so we could get baseline horsepower and torque ratings at the rear wheels. The diesel pushed out exactly 200 more lb-ft of torque and 67 more horsepower because the gas truck would not hold Fourth gear long enough to reach the advertised rpm for peak power. The gas engine likely has more horsepower than our dyno data shows.
This article was very skewed and seemingly the purpose was to justify the savings of going diesel...but their estimate of 3.93 years to pay-back the $6,000 diesel option did not include the addition expenses for oil changes air/fuel filters that cost way more than gas motors!!
