Alternator gauge
Thank you in advance.
marty60
What you describe is normal.
It has to do with the Voltage regulator.
The VR doesn't kick in until about 850 rpm so any reading at idle will show slight discharge.
If you do some tests of current drain (putting on Headlights.... then heater motor.... then windshield wipers) at idle....... then again at 1000 rpm you will notice what is going on with the charging system.
The Alternator / VR really only "top up" the battery.
When they are doing that ..the ammeter will read on the + side until the battery is charged right up then they go back to the 0 (center of gauge) ....unless the ammeter doesn't work anymore.
They are prone to going bad.
You have a voltmeter.. that's really all you need.
