FS2500 system
Old Aug 9, 2007 | 12:47 AM
Baddfx4's Avatar
Baddfx4
Smile FS2500 system
Anybody out there running 6.0L PSD installed FS2500 oil bypass system? Let me know how it performed, I am thinking about buying one. Thanks.
Old Aug 9, 2007 | 03:46 AM
BGMSPD's Avatar
BGMSPD
can't tell you much about that system but i have installed the OilGuard system. Works well and the install was easy, it's definitely a heavy duty piece. pics are in my gallery
Old Aug 9, 2007 | 07:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Oil Guard...IMO the best, I have had one on all my trucks.
Old Aug 9, 2007 | 11:50 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Old thread... my help you some??
https://www.ford-trucks.com/forums/4...n-reality.html
Old Aug 9, 2007 | 11:52 AM
Beachbumcook
Got Diesel?
Another old thread on same topic... may answer your questions as well??
https://www.ford-trucks.com/forums/5...er-system.html
Good luck...
Old Aug 9, 2007 | 10:21 PM
scafes's Avatar
scafes
Post
I use the FS2500 and am sold on it. There is no way you are going to damage this unit, it weighs in fairly heavy and is thick walled. I mounted mine on the frame rail under the drivers door. Easy to get to and change the filter. Bypass filters are a product that you must have a little faith in and believe the technology behind it. Proof is hard to come by on an OA. They work, all of them. You cannot go wrong with any of the major units on the market. The best thing Oil Guard has going is the cost of the replacement filters. String is cheap. Polyester is not as it is based on oil. TP is cheaper but must be changed every 1-2K approx. Too soon for most people who have a life to live.
Check out the testing that they did to their filter. The Southwest Research Institute tested it and proved what it can do. To my knowledge, not one other company has tested their filter by an independant third party.
I now change oil at 10K intervals and am pleased with the results. But that is another thread altogether.
Old Oct 10, 2007 | 04:57 PM
lawmans3's Avatar
lawmans3
I just installed one and would be happy to post some pics if anyone is interested. The FS 2500 is very heavy duty. The hardest part of the installation was drilling through the frame rail! I used one existing hole and drilled another.
Old Oct 12, 2007 | 12:53 PM
ericwc's Avatar
ericwc
Pics would be great.
Thanks for sharing
Eric
Old Oct 12, 2007 | 01:07 PM
raptor131's Avatar
raptor131
but as it is a bypass system if you don't change it on time it won't hurt anything. right?
Old Oct 13, 2007 | 01:04 PM
lawmans3's Avatar
lawmans3
Thanks for sharing
Eric
I'm out of town, I will them when I get back.
Old Oct 19, 2007 | 02:15 PM
lawmans3's Avatar
lawmans3
As promised. Here is a link to the install pics on my truck. Any questions let me know.
http://www.pbase.com/lawmans3/fs2500
Old Oct 19, 2007 | 03:52 PM
scafes's Avatar
scafes
No. The only possible problem is with the TP itself. Will it break down like it does in water? I don't know. Like I said, changing it that often is a hassle, I don't care how easy it is to do. Just think about how long it takes you to roll up 1K. On average, you would be changing it at least once per month, if not sooner.
Old Oct 19, 2007 | 03:54 PM
scafes's Avatar
scafes
Hey Lawmans, is that a custom unit you used to pipe into at the return? Are they now selling a kit to return the oil to the filler?
Old Oct 19, 2007 | 04:09 PM
satcom40's Avatar
satcom40
Yea I like that also the retune oil part that is.
Old Oct 19, 2007 | 05:29 PM
ericwc's Avatar
ericwc
Thumbs up
Thanks
Eric
