Tiny Tach question
Old Aug 8, 2007 | 02:01 PM
F250FarmBoy's Avatar
F250FarmBoy
Tiny Tach question
What size transducer do I need to install a tiny tach? 6mm or 1/4"?
Someone already told me what the pulse # is.
Thanks
Old Aug 8, 2007 | 03:04 PM
F250FarmBoy
I forgot I had a digital caliper.
I went and measured and it looks closer to 1/4" (0.258) than 6mm (6.78).
So I'll order the 1/4" transducer.
Old Aug 8, 2007 | 04:39 PM
catfish101's Avatar
catfish101
????? What do you mean "1/4 inch transducer". You motor doesn't have a place for the tach sensor in the gear cover housing over the pump drive gear.?
Old Aug 8, 2007 | 04:44 PM
F250FarmBoy
You place the transducer to an injector line and it measures the pulses with tells the RPM's.
The injector line is closer to 1/4" than 6mm.
Here's a link:
http://www.tinytach.com/tinytach/diesel.php#
Old Aug 8, 2007 | 04:53 PM
catfish101's Avatar
catfish101
I see.... Hey that might work for checking timing....
