Sponsored by: Real Truck
View Poll Results: Alternator Replacement
'04 sd/td alternator replacement?
25.00%
Serpentine tensioner help
75.00%
Voters: 4. You may not vote on this poll
Alternator Replacement assist
Old Aug 7, 2007 | 09:52 PM
flightstar's Avatar
flightstar
Hey gang!
Anybody out there had occaision to replace an alternator in an "04 SD/TD?
Releasing the tensioner on the serpentine belt appears WAY morre difficult than All my other vehicles...... I don't want to have to pull the cab off for this!! Any Ideas?
Old Aug 7, 2007 | 11:48 PM
Monsta's Avatar
Monsta
Sit. Stay.
What's the poll for???
Have you attempted to release the tension of the belt yet??
Old Aug 8, 2007 | 01:38 AM
flightstar's Avatar
flightstar
Yeah, belt tension, that's the prob. The location of the 'business end' of the tensioner seems inaccessable w/out removing the cooling schroud and fan. Is there a special tool or am I just seeing it wrong?
Old Aug 8, 2007 | 08:41 AM
RXevolv's Avatar
RXevolv
Take a 1/2 in socket driver, and slide the square end down to the front of the tensioner, with the handle standing straight up.
Wiggle a hand to the front of the tensioner, and fit the 1/2 into the square opening.
Attach a wrench or something to increase leverage or lenght of tool.
If possible, have a friend slide the belt off the pulley while you crank counter-clockwise on that tensioner.
You shouldn't have to remove anything at all. I have a 1999, but I suspect that it is the same.
Old Aug 9, 2007 | 01:47 AM
flightstar's Avatar
flightstar
Got it! I also found the 'Pin' that holds it, the tensioner, 'sprung' while detatching the belt. thx to you, gang! I tell you, hanging out with the 'Folks-in-the know' sure helps!!
Old Aug 9, 2007 | 03:16 AM
RXevolv's Avatar
RXevolv
Do you still have the old alternator? I could rebuild it
Old Aug 10, 2007 | 01:49 AM
flightstar's Avatar
flightstar
I bought a new one and they want the core. What are you getting ($) for your rebuild?
Old Aug 10, 2007 | 02:35 AM
RXevolv's Avatar
RXevolv
It's for myself as a spare for parts. How much is your core charge... if it's low enough I could pay
