1978 - 1996 Big Bronco
2wd tranny
Old Aug 7, 2007 | 09:29 PM
mutang02's Avatar
mutang02
2wd tranny
I have an 87 bronce with a 5.0 and a not factory 3-speed auto. I also have a wrecked 92 f-150 2wd 5.0 5-speed. Is it possible at all to retrofit the tranny so that it will bolt up to the transfer case? I am a machinist so making parts is not out of the question, I know I will probably have to get a 4wd 5-speed out of a junkyard. I was just hoping to use the tranny i already have. Thanks
Old Aug 7, 2007 | 10:33 PM
mrknight01's Avatar
mrknight01
You would have to replace the output shaft and rear case half. On a standard trans. you would have to tear the Trans completely apart to do this. You would be better off selling it on e-bay or somewhere else. And getting the right one.
Old Aug 8, 2007 | 08:21 AM
Kemicalburns's Avatar
Kemicalburns
and since you have to sell it anyway. get a zf 5speed. far more durable then the m5od you currently have. although that 3speed in your current bronco, thats a C6 right or is it the manual 3 speed?
Old Aug 8, 2007 | 07:52 PM
mutang02's Avatar
mutang02
the transmission in there now is an automatic but the truck originaly had an overdrive auto, some previous owner had installed the 3 speed i dont know if it is a c-4 or a c-6. it doesnt matter. I cant afford 8mpg anyway. what aplications did the zf come in? thanks
