heater/blower/Fan speed switch?
Old Aug 7, 2007 | 07:15 PM
MBBFord's Avatar
MBBFord
Question heater/blower/Fan speed switch?
How do you replace the blower/heater speed switch on these trucks? I'm trying to do it on my 77 F100 w/ factory A/C.
I took everything apart to get to it, but I could NOT get it off. I don't know if there is a secret clip or you need super man strength to take it off. I pulled so hard I thought something was going to break so I stoped.
Any help would be greatly appreciated.
Old Aug 8, 2007 | 02:12 PM
Mil1ion's Avatar
Mil1ion
I thought there were 2 screws holding it in ?
Old Aug 8, 2007 | 05:20 PM
MBBFord's Avatar
MBBFord
I already don't remember, but I know for sure there was at least one. I will look better for the other one tomorrow. Thanks for the diagram.
Any thing else tricky to it? Clips on the port that attatches to it needs to be removed?
Old Aug 8, 2007 | 05:21 PM
tractoman's Avatar
tractoman
Mine only has one screw that goes through the wing like piece that sticks out the side accesible from the bottom with a long phillips.
Old Aug 8, 2007 | 06:12 PM
MBBFord's Avatar
MBBFord
Did you have any kind of trouble take the clip(of wires)off the back? I can't seem to get it off.
Old Aug 9, 2007 | 07:36 PM
MBBFord's Avatar
MBBFord
Question
Mine has one very small hex head that connects the switch.
I just changed it(switch), and my fan still isn't blowing.
I can hear the little blower motor and so can my mechanic(who was trained on this model truck, and has never steared me wrong before).
The problem has to be something else.
It's not the switch, fuses, or the blower motor, so what else can it be?
Mil1ion, if you could, please explain what I need to do, because the 100 degree heat and 100% humidity is KILLING me. Relay, wire? What and where?
Old Aug 9, 2007 | 07:55 PM
Mil1ion's Avatar
Mil1ion
If the motor is turning it should be blowing.
have you checked all the vacuum actuators to open the AC doors ?
Old Aug 9, 2007 | 08:03 PM
MBBFord's Avatar
MBBFord
I hear something that sounds like it's turning right where the blower motor is, it's not to loud, but it's there. I didn't check the vacuum actuators to open the AC doors, how would I do that?
Old Aug 9, 2007 | 08:05 PM
Mil1ion's Avatar
Mil1ion
By moving the slide cable across to various positions and listening for things changing.
Old Aug 9, 2007 | 08:25 PM
MBBFord's Avatar
MBBFord
I thought it might of had something to do with that, but I wasn't sure....
Either way, I checked, and that's working perfectly.
What are my other options? (even if for some reason the blower motor isn't working, it could be that and what else(so I can change everything to eliminate all possiblities))?
Thanks for the help so far, I really appreciate the quick replies.
Old Aug 9, 2007 | 08:28 PM
Mil1ion's Avatar
Mil1ion
Did you try a jumper wire to the motor leads for direct 12V to see what happens ?
Old Aug 9, 2007 | 08:31 PM
Mil1ion's Avatar
Mil1ion
Here's everything I have.
Old Aug 9, 2007 | 08:32 PM
MBBFord's Avatar
MBBFord
No. What do you mean by that? Volt meter test?
I do not have the blower motor visible. Is there anything I can do that would by pass something (I don't know, I'm desperate)?
Old Aug 9, 2007 | 09:20 PM
MBBFord's Avatar
MBBFord
Ok, I'll study the heck out of the diagrams, and see if I can come up with something tomorrow, since it's jet black outside now.
I greatly thank you for the help.
