Clearing out a Check Engine Light trick?
Old Aug 7, 2007 | 03:47 PM
97RangerDanger's Avatar
97RangerDanger
Hi,
I've got a 97 Ranger 2.3L. I recently had to have the gas tank dropped and the fill hose replaced. Ever since my check engine light has been on. I took it to the Vato Zone and they ran a P1445 or whatever the EVAP code is. I asked a question about getting the light to go off so I can get it inspected, and someone told me a trick that sounded idiotic.
She told me to:
Unhook the battery
touch the positive cable to the negative side for 20 seconds
At first I though that would fry my fuseable link or just fry my computer. However, after thinking about it she did say to disconnect the negative end. Will this work?
Any more help on this problem would be appreciated...
Old Aug 7, 2007 | 03:52 PM
pgw85706's Avatar
pgw85706
Welcome to FTE. Why not ask the store that read the code for you to reset it and see if it returns. I do not recommend shorting it out, but you could try and disconnect your battery for 30 minutes to see if the computer will clear.
Old Aug 7, 2007 | 08:00 PM
jimdandy's Avatar
jimdandy
The evap system is at the fuel tank. My guess is that whom ever pulled the tank did not get it back together correctly. Take it back to who ever did it and have them re-check. jd
