1978 - 1996 Big Bronco
no start unless???
Old Aug 7, 2007 | 10:13 AM
toughtransam's Avatar
toughtransam
no start unless???
got a 95 bronco with 5.0, sometime when you try starting it when its cold it wont start unless you feather the gas a little and then when it does start it sounds like its loaded with fuel really bad until you get a couple of revs out of it to clear it out,, and it will be fine for awhile,,, would this be a fuel presure regulator problem??
Old Aug 7, 2007 | 10:44 AM
Kemicalburns's Avatar
Kemicalburns
could very well be. pull the vacum line and see if gas comes out. that would mean bad fpr , also check your fuel pressure at the rail with a gauge. also check your oil and smell it for gas. if gas is in the oil do not drive it anymore, it could cause engine failure
Old Aug 7, 2007 | 11:52 AM
toughtransam
ok its not the fpr,, and the oil is fine,,, any other ideas
Old Aug 7, 2007 | 12:34 PM
Kemicalburns
pull codes, www.fordfuelinjection.com has instructions.
Old Aug 7, 2007 | 01:48 PM
toughtransam
pulled a code 33 egr valve opening not detected, i know what the egr does, and i know they rarley go bad, and usually have to cleaned do to carbon build up,, does this sound like a possibility for a hard start
Old Aug 7, 2007 | 03:38 PM
chexmix's Avatar
chexmix
The sensors do go bad often though... Also, is that a fresh tank of gas? Could simply be vapor lock.
Old Aug 7, 2007 | 03:39 PM
Kemicalburns
when was it tuned up last with new copper plugs,wires,cap,rotor and fuel filter? also check timing with spout connector removed once vehicle reaches temp
Old Aug 7, 2007 | 05:59 PM
toughtransam
its been doing this for awhile and continully gets worse, just did a tune up on it and replace the fuel filter and fuel pump about 3 months ago, im going to try cleaning the egr out tomarrow and hopefully that will solve, going cheap and easy first
Old Aug 8, 2007 | 08:24 AM
Kemicalburns
you need to check fuel pressure at the rail with the key on, then with the engine running. have you checked the timing?
Old Aug 8, 2007 | 09:52 PM
toughtransam
i have not checked the timing but i am almost positive that is not it,, it only does this once in awhile not all the time,, i checked the egr and it is clean and working,, i had another hint from a ford guy saying it may be a throttle position sensor
Old Aug 9, 2007 | 09:56 AM
GIXXED's Avatar
GIXXED
I have the same issue right now. all the top end sensors have been replaced and no codes come up at all. I am changing out the Distributor on it now do to the TF Ignition module on the side it. I have been told that this could be why I am experiencing some similar issue. But Mine also feels and sounds like it is missing when it is at running temp right around 1500 to 22-2500 rpm (this is when it is most apperant)
