2 Questions
How often should I change shocks? Would it be a good idea when I get new tires after the first of the year to change the shocks as well. I have Rancho 5000 and might go with the Bilsteins HD's.
Second, what kind of ordeal is it to make the front passenger seat of a 2001 a power seat? I have decided to keep my '01 even though I have 215,000 +- miles and I already have to ge the driver seat replaced because the seat track is broken, so I might as well replace them both. It would make the litte lady I live with(for 21+ years) more comphy.
John in Mobile
'01 PSD 4 X 4
As far as the replacement brand goes, I went with Rancho 9000. They are adjustable via a small dial on the shock itself. This works well for customizing the shock for towing vs. highway driving, vs. pothole hopping... The Bilstiens have a good reputation on this forum, but some have commented that they are a bit stiff and I thought that was the last thing my already "rough-riding" X needed.
Unless your Ranchos are leaking or have lost all dampening then save your dough. You don't need new shocks.
John in Mobile
'01 PSD 4 X 4
Now for the power seat. The required power seat connections may be stored under the carpet under your current seat. It may be as simple as installing a power seat, making the connections and installing a fuse. I believe several years ago car makers went to one wire harness fits all vice a different harness for each option. Not sure but may be worth checking. Also suggest you check the fuse panel to see if there are wires in the power seat fuse location where there is probably no fuse. That would give you a clue if the wires are run in the harness.
DSMMH
