Is 89 Octane Bad for Engine?
Old Aug 29, 2002 | 03:45 AM
wgm114's Avatar
wgm114
I know that the owners manual calls for 87 octane fuel. Does it hurt anything or gum up the works to run 89 octane instead? Aside from the extra money I was just wondering.
Thanks. Bill
Old Aug 29, 2002 | 10:10 AM
MrBSS's Avatar
MrBSS
Usually doesn't hurt OR help. No reason to spend the extra money.
MrBSS
Old Oct 3, 2002 | 01:49 AM
bam78bam's Avatar
bam78bam
i have heard this debate from alot of people, most of whom are mechanics and shade tree mechanics. they normally say run better gas. but as far as engineers and chem. they say just run a good grade of 87. your vehicle was designed for it and that is all it really needs. now after high mileage or add ons, just let the motor tell you what it wants. carbon will build up eventually but a more expensive gas won't prevent this. lets say you upto 10cents more a gallon everytime you go to the pump. well i have a 30 gallon tank that i fill up at least once every week if not more. i could just buy a new motor down the road with what i saved.
Old Oct 3, 2002 | 10:08 AM
Petrol's Avatar
Petrol
Very good explaination. . .but for one very common misconseption . . . The Octane rating for a given grade of gasoline has NOTHING to do with the quality of the gasoline. The Octane rating is simply a way to rate a fuels resistence to detonation prior to planned ignition (spark) due to the heat of compression and combustion chamber design
Old Oct 15, 2002 | 03:09 PM
PaulC's Avatar
PaulC
I live in a hilly area with my 4.6 Expedition. I usually fill-up with 89 in hot weather to combat detonation-aggravating ambient temperatures.
Old Oct 17, 2002 | 04:07 PM
MrBSS's Avatar
MrBSS
Well, whatever works, but you really shouldn't have much detonation on regular, hilly or not.
MrBSS
Old Oct 18, 2002 | 06:45 PM
Buck000's Avatar
Buck000
