Sponsored by: Real Truck
Horn
Old Aug 6, 2007 | 05:09 PM
mstiles19's Avatar
mstiles19
Horn
My horn low tone horn has died and i can not find it. I have an 2001 F250 SD with the 5.4.
Old Aug 6, 2007 | 05:14 PM
SpringerPop's Avatar
SpringerPop
Inside the passenger's front wheel well, behind the plastic inner liner.
Pop
Old Aug 6, 2007 | 06:06 PM
Monsta's Avatar
Monsta
Sit. Stay.
There are 4 or 5, 5.5mm bolts to remove and 3 or so 8mm. Once you pull the liner down a bit you can access the horns. They are up in the front corner. They are held on by a bolt right behind the battery on the inside of the fender.
