The shipment placard is for accident responders... It is not for you to stay away from the truck... the radiation exposure rate at the surface of an unbroken package should be no more than 1,000 mR/hr at time of shipment and even this is worst case scenario. To put this in perspective you get an annual dose of around 2,400 mrem from Radon daughter products you inhale.... in your home!
Depending on the material being shipped, they have different dose rate limits... White I, Yellow II and Yellow III with a maximum rate of 200mR/hr.
Then there are the shipping containers themselves.... It just gets more complicated from here
(1 mR/hr is about 1 mrem where mR/hr is exposure rate and mrem is exposure dose.)
I think you meant....240 mrem. The rest (~100 mrem) of the annual average comes from cosmic radiation, food (1 in ever 8000 potassium atoms is radioactive) and the ground you walk on.
BTW, this national average (~360 mrem/year) is about the equivalent of 60 standard chest x-rays...or about 1/4 of a full body CT scan.
I looked up 2908 in our DOT emergency response guidebook and it's very low radiation stuff and empty packages capable of carrying very low radiation stuff.
Basicly, it's nothing. It only recommends us to wear our bunker gear and SCBA, which are not designed to block radiation at all. It's probably something that emits alpha particles at best that a normal T-shift can stop and even if you did get "exposed" probably nothing would happen.
that placard like said above is for an accident...
that gives whomever a is there first the knowledge of how to respond....open the truck door and get the hazmat book(if its not burned up or something) and flip to the section matching that placard and you will have a brief explanation of what to do etc...
Damn im rusty on my hazmat stuff
im glad i never got the hazmat endorsement, too much crap to remember, not to mention the liability
Let me be more specific... "2,400 mrem dose equivalent to bronchi from radon daughter products. The assumed weighting factor for the effective dose equivalent relative to whole-body exposure is 0.08." SOURCE: BEIR (1990), p.18
Its not so much the radon gas thats bad, its the daughter products associated with the gas thats dangerous when inhaled...
200 mRem is correct for radon gas in a total body exposure, not inhaled.
Basically its nothing to worry about. Like stated in a accident even if it did get all over the place a minimal amount of protection would be recommended.
Now say this thing had escorts and as stated before there were specialized containers that basically sheilded you from the radiation coming from the container then yeah that is something not to mess with.
Only properly trained individuals should respond to spills be it chemical or radiological. These trained responders already know what to do by looking at the placard and shipping containers. They may wish to access the shipping manifest to see any pertinent information such as chemical form to be sure of reactivity with other agents. hazwoper training does't really cover radiological spills in detail as it is primarily for hazardous materials non-radioactive in nature.
Lets say this truck is flipped in a ditch and you come accross it. You notice that there is some fluid coming from the back or through a crack somewhere. This should not stop you from assisting with any injured person at the scene. This should stop you from addressing the spill itself. When calling for help it is important that you describe the placard and spill so that the proper personnel can arrive.
if you can get to the cab of the truck in an accident the BOL is required to be reachable by the driver strapped in the seat, or reachable from outside the door (either on the seat itself or in the door pocket) on a BOL for any hazmat load including radioactive there will be a emergancy response number you can call and detailed information about that load will be on there also.
You are correct, my quote was for total effective dose. The radon progeny have higher energy than Rn-222 and are much more damaging. The good thing about these is that they are mostly short lived. However, the Polonium-210 is a dangerous alpha emitter. Since alpha radiation (for those who care, a particle equivalent to one Helium nuclei) has such a high mass, it has a low speed and can be stopped by light material, even a sheet of paper, which is good news.
For what it's worth, most smokers recieve about 7 times more dose to the bronchial epithelium from the Po-210 found in tobacco than the average person does from Uranium or any of its daughters, which is about the equivalent of 2000 regular chest x-rays for a heavy smoker.
Thanks for the info, I have not read much about equivalent dose delivered from radon as it isnt clinically used to treat cancer.
BTW, what do you do that you know so much about the transportation of radiation?
