AOD compatible....
Old Aug 6, 2007 | 07:24 AM
Rbomar's Avatar
Rbomar
AOD compatible....
Is an AOD from a 1988 2 wheel drive F-150 the same as an AOD from a 1988 4 wheel drive F-150? I have the 4 wheel drive with a bad AOD and want to swap it out with an AOD from a 2 wheel drive F-150 of the same year.
Old Aug 6, 2007 | 08:48 AM
Casey's Avatar
Casey
The output shaft and extension housings are different. They can be swapped, but the trans has to be completely torn down to do it.
