Anyone know what is required to remove the front leaf springs on a 03 FX4? I can not figure out if I am going to need to remove the condenser to remove the front bolt? Thanks!
when i removed mine, i had to remove the bumper and then drop the front hanger in order to get enough room to get a wrench or ratchet on the bolt head.
Just unbolt the lower condenser brackets one at a time, so the condenser doesn't fall, and then if necessary, you can slightly move the bottom of the condenser for bolt clearance. I changed my front springs a couple of years ago, and I DID NOT have to remove the condenser. Removing the front bumper gives you easy access to everything also.
