Door actuator fix???
I removed my rear door actuator and it looks nothing like the one in pictures for the fix.
https://www.ford-trucks.com/forums/4...cks-fixed.html
Any help is greatly appreciated.
Thanks
The parts inside are the same and I did the foil trick and everything is working fine.
My truck is a 2003 and all you have to do is remove the one linkage that tat the actuator rod attaches to. It comes off in less than 5 minutes.
