Power Accessory Relay Help
Old Aug 4, 2007 | 12:49 PM
wgm5286's Avatar
wgm5286
Just purchased a 2006 mountaineer. Installed a new pioneer d3 nav radio. The problem i'm having is that the power accessory relay is not working. So when you shut off vehicle, so does the radio. I looked for the relay, i think its in a hard to get place on the left side of the smart junction box. Question, should the power windows still be working if the relay is bad? They do. I put the stock stock radio back in and it shuts off too, so i know its not my wiring. Any help to get to the relay or a way to solve this problem would be appreciated.
Old Aug 4, 2007 | 02:06 PM
Steina's Avatar
Steina
CO River Rat
The windows in my '04 continue to work for 10 minutes after the key is turned off, or until I open a door; the radio turns off right away. Are you saying the radio has no power with the key in ACC position?
Steve
Old Aug 4, 2007 | 02:52 PM
wgm5286's Avatar
wgm5286
no, the radio works until the key is shut off. At that point the accessory delay relay is supposed to keep it on until a door is opened, or until the ten minute delay is reached.
