Helloooooooo FTE!!
Old Aug 3, 2007 | 08:48 PM
stroke-of-luck00's Avatar
stroke-of-luck00
Talking Helloooooooo FTE!!
Just wanted to use my first post to say hello to everyone. I've been lurking for quite a while and this site is GREAT! I'm sure I'll be bugging you guys with lots of questions in no time...my truck is acting kind of suspect right now so I'll appreciate all your feedback! Adios!
Old Aug 3, 2007 | 08:54 PM
ryaneverk2's Avatar
ryaneverk2
Welcome aboard!
Share some info on your truck if ya don't mind.
Old Aug 3, 2007 | 08:55 PM
totin_tools's Avatar
totin_tools
Welcome, we all learn something from this board. They have been helping me for awhile. Once again welcome.
Old Aug 3, 2007 | 09:02 PM
nedaclu's Avatar
nedaclu
hello and welcome
stroke-of-luck00
Picked up a '00 F-250 4x4 with 190,000 on the clock. pretty much bone stock except for straight piped exhaust. I guess i'll go ahead and start with my ?'s now...i was pulling my boat today (approx 6000 lbs) and had to absolutely bury it to get to 75 and really keep the pedal mashed to keep it at 65. low end torque is fine but i'm not really impressed on the highway. also, when it shifts into 3rd under moderate acceleration (E4OD) it shudders pretty bad. any idears??
Old Aug 3, 2007 | 10:20 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Hey stroke-of-luck, first step here is a check of all the IC boots. Make sure you do not have a boost leak. Towing power will suffer miserably. As for the shudder on the 3rd gear shift, does it do it every time no matter what the throttle? Again, make sure no boost leaks and also check the up pipes for soot. Step by step stuff here. Welcome aboard the good ship 7.3.
Old Aug 3, 2007 | 10:25 PM
blksiryder's Avatar
blksiryder
hello from new orleans stroke. let us know if we could be of any help
Old Aug 4, 2007 | 01:37 AM
bigjake0524's Avatar
bigjake0524
Welcome to the site, there is a mass of informantion here. Best of luck with your truck.
Old Aug 4, 2007 | 07:10 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Welcome to the site and to PSDs. You will never drive a POS gas truck again now that you have a real truck.
I second what Mike (Tenn) says about the IC boots. I recently went through and tightened all of mine and the gain in performance is unreal for something that took 30 minutes and was absolutely free.
If there are any other questions just ask. There are experts here on just about every subject relating to diesels. I'm not one of them though.....ha!
Old Aug 4, 2007 | 07:30 AM
Kwikkordead's Avatar
Kwikkordead
Welcome to FTE.
Shuddering when shifting could be a bad transmission, but I think it's more likely that you have a bad injector that is cutting out. Especially with the decidedly lackluster performance that you are describing. These trucks when you load them up are much more capable than what you are describing.
Old Aug 4, 2007 | 08:44 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Hey stroke of luck... Welcome to FTE. A few tips, the blue bar running across the near-top of the screen, the far left button is User CP. Click on it, and on the left side is all of the user-changable settings. Fill in your signature that appears below posts, where you are from, what you do, etc. Alot easier if someone here lives close with you, possibly having a scanner or something.
Old Aug 4, 2007 | 10:49 AM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
hello to you too, enjoy your stay, give us more info on your truck, that would help too,
Old Aug 4, 2007 | 12:56 PM
stroke-of-luck00
Thanks for the reply's everyone. Ok, I'm pretty slow when it comes to diesel engines. I'm assuming that ya'll are talking about IC (intercooler) boots?? Do I just look for a hose clamp to tighten or what? What hoses should I look for soot in?
Kwikkordead...i just towed my boat again this morning and it is DEFINITELY a drivetrain problem. Sometimes the shudder is from 2nd to third or 3rd to 4th. If i am VERY easy on the throttle it doesn't really shudder too bad. I'm getting kind of nervous that I have a suspect tranny.
Again, thanks for all the replys!
Old Aug 4, 2007 | 01:12 PM
John311t's Avatar
John311t
Welcome to FTE.
Your trans is a 4r100, the e4od is the old verision in the OBS trucks. There are a coupel difference IIRC between the two. The IC boots are intercooler boots, and you will see 4 of them, if you look at the top of the engine locate the turbo its in the back directly in the middle of the motor, come out of the turbo you will see a 5 way manifold, then you will see a boot with a long tube coming out of it, thats the intercooler tube. Connecting the 5 way manifold to the spider is a the boot and it has 2 clamps on it per boot. Make sure they are tight and they are not blown off, sometimes oil can make them slip off. The mod called CCV mod stops the oil from getting in the intake. Just follow the tube there is 2 on the passenger side and 2 on the drivers side, you will see where it goes into the intercooler. 8 clamps alltogether. Just dont overtighten them.
The shudder problem, could be injector or trans. Does it also do it unloaded?
