Sponsored by: Real Truck
Broken keyless entry/steering too
Old Aug 3, 2007 | 03:27 PM
powerstroke6ltr's Avatar
powerstroke6ltr
Which fuse is the keyless entry? I can't seem to get the truck to go into program mode. Truck is an '02 lariat so it should have keyless if I am thinking right. Has every other option. The other problem is, when i am stopped regardless of whether my foot is on the brake or not, the steering wheel wont' turn more than 1/4 turn. Then it gets really difficult to turn. Hydroboost brakes. I realize if your foot is on the brake it will be more difficult to steer, but this doens't seem right. Sounds like a pump issue or steering box?
Old Aug 3, 2007 | 04:29 PM
redford's Avatar
redford
FTE Leadership Emeritus
Sounds like a pump issue. Have you checked the power steering fluid level?
Old Aug 3, 2007 | 10:36 PM
powerstroke6ltr
Yup. looks good to me. Fluid is a bit dirty though. The truck is a diesel too...forgot to mention that...
Old Aug 4, 2007 | 08:57 AM
redford's Avatar
redford
Yes, we figured that because of the hydroboost.
I'd change the fluid then see how it behaves.
As for the fuse....per the manual at
http://www.analogstereo.com/pdf/om/f...anual_2002.pdf
you should be examining fuse 102 and maybe fuse 19.
Old Aug 5, 2007 | 01:06 PM
F250tuff's Avatar
F250tuff
Do you have over-sized tires?
Old Aug 5, 2007 | 03:50 PM
powerstroke6ltr
Fuses looked good. What else does the Gem control on these trucks?? Could it be the GEM is bad?? The tires are 305s on 16" rims. A tad wider and a bit taller...
Old Aug 6, 2007 | 11:42 AM
F250tuff's Avatar
F250tuff
I was thinking that if your tires were too wide, then they may be over-powering the power steering pump (at idle). If you still have access to the stock wheels/tires you could throw them back on the front to see if it makes a difference.
I don't know about the keyless entry.
Good luck.
Old Aug 6, 2007 | 12:10 PM
powerstroke6ltr
I tried idling up the motor and it still won't turn the tires. Don't have the original tires anymore. If i start to roll really slowly the wheel turns fine, just stopped regardless of brake input.
