5.4 ltr. V8 Excursion
Old Aug 3, 2007 | 08:13 AM
crashnburk's Avatar
crashnburk
I can't find any specs. for a 5.4 ltr. V8 2001 Excursion. What is the towing capacity, and did it come standard with 3.73 gears? It has 38" tires. Any suggestions on what to do first for more pulling power without buying a new vehicle?
Old Aug 3, 2007 | 08:16 AM
njstevens's Avatar
njstevens
If this X has 38's then it must have some work done to it. If you have 38 and 373 your in for some issues. The truck will not go anywhere. At the minimum you should have 430 which with a 38 would bring the ratio to approx a little more then 410.
Old Aug 3, 2007 | 10:23 AM
crashnburk's Avatar
crashnburk
Big Truck Little Engine
I bought it this way and don't know what gears are in it. It just towed a 30' Travel trailer and it would do about 30 - 35 mph on 7% grades with seven people in it and four dogs.. When trying to get started after a stop it would take a bit to get moving. It currently has no after market exhaust,air intake, or power chip. I am guessing it wasn't geared for the oversized tires. Is there any way to tell with out going to a mechanic, and doing it in the drive way?
Old Aug 3, 2007 | 04:13 PM
EpicCowlick's Avatar
EpicCowlick
I don't think it's going to matter what exhaust, intake or chip you put in that 5.4L. With those 38's, there's just not enough displacement for such a big beast. I moved up from an Expedition to an Excursion because the Expy just didn't have enough umph. You have an Expy engine in an X which weighs about 2000 lbs more, I think. Oui. If you're going to stay with that vehicle, just get used to the lower speeds on inclines.
Old Aug 3, 2007 | 04:34 PM
Monsta's Avatar
Monsta
Sit. Stay.
First of all use this calculator to get you exact tire size.
http://www.miata.net/garage/tirecalc.html
The use this calculator to determine you RPM at a given speed. Use the one at the bottom of the page. And use .71 as your OD ratio.
http://www.csgnetwork.com/multirpmcalc.html
Try to get in the 2200RPM range for 70mph ... or around 1950RPM for 60MPH. That will put the engine in its optimum power band and is similar to running stock tires with 4.30 gears. Save all the other dough you want to spend on intake, exhaust blah...blah...blah...
Old Aug 3, 2007 | 06:56 PM
CounterMaker's Avatar
CounterMaker
ya i agree... if you are running stock 3.73 gears, i say def. regear or if yuo dont mind, throw on some smaller tires...but still i would suggest a regear...i personally dont think the 5.4 and 3.73 gears is a good mate in such a large vehicle...and i have one of em...lol...a 2006 f250 5.4 3.73. i recently purchased 35" tires and i will be regearing to either 4.3 or 4.56's...good luck and keep us posted...here is a good place to get some gears...http://www.ringpinion.com/
Old Aug 3, 2007 | 08:05 PM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
My first upgrade would be from here: (if I could scrounge up the money) http://www.fordcummins.com/
It wouldnt be cheap though.
Old Aug 3, 2007 | 08:07 PM
Monsta's Avatar
Monsta
Sit. Stay.
And what does that have to do with this thread??
Old Aug 4, 2007 | 06:52 PM
RCKYMTN-PSD
?? Well you see... if you installed one of those motors for sale there, you would have more pulling power.
Do you get it now?
Old Aug 4, 2007 | 07:01 PM
bigblock_drock's Avatar
bigblock_drock
prolly alot cheaper and easier to just buy and expy w/ a diesal or V10
Old Aug 6, 2007 | 12:47 AM
JUMBO_UTE's Avatar
JUMBO_UTE
To the best of my limited knowledge, Expy's were never offered with a V10 or Diesel.
Old Aug 6, 2007 | 02:27 AM
Monsta's Avatar
Monsta
Sit. Stay.
Expy = Expedition.
Ex = EXCURSION.
Old Aug 6, 2007 | 02:32 AM
1's Avatar
Ilol pray for your trans.
Old Aug 6, 2007 | 11:13 AM
bigblock_drock
i meant EXCURSION.. im a little slow
Old Aug 6, 2007 | 03:42 PM
i eat hybrids's Avatar
i eat hybrids
Doesnt that cummins place install the cummins engine for you or do you have to do it your self?
John Hancock
Modular V8 (4.6L, 5.4L)
23
Jun 15, 2019 12:55 PM
Doitmyself365
Jul 24, 2015 09:38 AM
mattymax
Oct 2, 2014 07:56 PM
DanK5
1997 - 2003 F150
Mar 31, 2014 01:46 PM
Dalma
1997 - 2003 F150
Nov 21, 2001 09:10 PM
