Fuel Tank Replacement
Old Aug 2, 2007 | 08:58 PM
jkrums's Avatar
jkrums
Well, found a leak in my main fuel tank today. Rather than messing around with it I am just going to order up a replacement, and replace it outright. Patching a 20 year old fuel tank doesn't seem to make to much sense.
My question then is - this is one of those things I have never done before and I want to do it all in one afternoon. Anyone have any cautions / got-cha's / etc that I might run into. You know when you get into something like this; it is the fifty cent part on backorder that you forgot that always prevents you from finishing - or that's my luck anyway..........
THANKS!!!!
1985 F-150 4wd Short bed
Old Aug 2, 2007 | 10:52 PM
fellro86's Avatar
fellro86
WHich tank are you referring? Either way, not too bad a job... Don't get too hung up on the bolts, it's easier if they do break, and just put new ones on. If you can have all the fuel out, or at least most of it, sure makes the job go easier.
Old Aug 2, 2007 | 11:01 PM
jkrums's Avatar
jkrums
the 19 gallon main tank in the back is the one I am replacing. I am trying to use up the fuel in it now. The leak is not too bad so I am just going to run the trank dry. I have some rust-penetrator on hand for the bolts. It seems to be my trucks best friend when it comes to jobs like this!!
Old Aug 3, 2007 | 12:16 AM
Franklin2's Avatar
Franklin2
Check the straps, you may need new ones. Get a new o-ring for the sending unit. Get some new bolts with long threads, you will probably end up twisting old ones off.
Old Aug 3, 2007 | 09:54 AM
opensourceguy's Avatar
opensourceguy
I went through this fiasco, broke every bolt but one for the tank. May as well just pick up some 9/16" head, 2" bolts w/ nuts and washers, two per bolt. So 4bolts, 4nuts, 8washers. And if you have a hitch, you'll break those too just like me. I don't tow so I never put that back on.. I reused my straps, amazingly they were will okay looking, and even the rubber was 'usable'... but it's not a bad idea to replace them.
Old Aug 3, 2007 | 10:48 AM
lisagoud's Avatar
lisagoud
DEPENDS ON WHERE YOU LIVE, iF nEW eNGLAND, PLAN ON BUTING A BRAND NEW SENDING UNIT WITH NEW PUMP, O-RING, LOICKING RING, STRAPS AND PERHAPS FUEL LINES (hOW i LOVE ROAD SALT WITH sNOW AND OCEAN WATER)!!!
Old Aug 3, 2007 | 09:36 PM
MikeFlorida's Avatar
MikeFlorida
Vent Bushing
If your new tank does not come with a new vent bushing you will want to change it. I had to buy mine at the Ford dealership for around $7 If the vent bushing is worn it allows dirt, water etc; to enter your tank. I also installed thin rubber strips between the straps & the tank (basiaclly extra protection). The hoses are easy to remove from the sending unit after you take the clips off the connector. I also put di electric grease on the plug end connection when I re-installed mine. Hope the info helps.
Mike
Old Aug 7, 2007 | 07:59 AM
jkrums's Avatar
jkrums
Thanks for all the tips everyone. I am going to hopefully do this the coming weekend and I will be a lot more informed when I start. I will post the results when I finish.
