beeping dash
Old Aug 2, 2007 | 07:26 PM
bigdog55's Avatar
bigdog55
beeping dash
This is kinda the same post as mine about the radio beeping when I hit a good bump,but,I have narrowed it down the fact that it's not the radio and I still can't figger it out..It does it when the radio is off and still does it when the radio fuse is pulled..
It's probably the little guy from homeland security in the little black box that tells big brother where you are and who you are...Oh Well....George Orwell wrote about it 50 years ago and we didn't believe him...
Old Aug 2, 2007 | 10:19 PM
RACERX7775's Avatar
RACERX7775
is your air bag light on? does it come on when you first start the truck? if not, its telling you that the system needs attention..
Old Aug 3, 2007 | 12:42 AM
bigdog55's Avatar
bigdog55
Hummm !! Guess I'll have to check it in the AM.. I do make sure that all the lites that are supposed to go out,do so.. Problem with that one is that it's outta the way to see it behind the wheel..Normally,that is second nature to me as I have to make sure the computer board on my school bus is clear before starting the emgine,but it's all where I can see it easily...
Old Aug 3, 2007 | 06:25 PM
bigdog55's Avatar
bigdog55
Well,I checked and everything self tested as it should have and all the lites went out they are supposed too..
Guess I'll have to check with the dealer and I don't trust two outta three of the Ford dealers in this area.. I get all my work at the local Lincoln dealer and he's got a Ford Diesel guy that's GOODddddd...
