Sponsored by: Kumho
Tire Question.. Load E VS Load D
Old Aug 2, 2007 | 04:29 PM
tgrim81's Avatar
tgrim81
I have an 88 F250. The stock tires are 10 ply load E, but to get larger load E tires is going to hit me hard in the wallet... Is it ok to use a D-rated tire? What are the consequences?
Thanks for all your help!
Old Aug 2, 2007 | 04:38 PM
wrenchturner's Avatar
wrenchturner
load rating is a two digit number. The letter you had is the load range which is the number of plys. D is 8 E is 10. It would affect weight capacities of your truck. you could find a comparable tire in that number of plys most likely.
here check out this site, you'll need to scroll down a bit.
http://www.dualport.com/bustech/load_tires.html
Old Aug 2, 2007 | 10:59 PM
aurgathor's Avatar
aurgathor
What you mostly need is the load rating in lbs, not the load range letter representing the number of plies, which may or may not be correct (my load range C tires have 5 plies, for instance), though load range normally indicates the max PSI. (35, 50, 65, 80, etc.) .
A D should be fine unless you tow or carry something really heavy.
north2south006
Mar 4, 2011 10:16 AM
musclecars90
Sep 30, 2010 08:25 PM
whiteaddiction
Feb 5, 2009 03:38 PM
diver45
Dec 5, 2007 04:45 PM
bullit340
Nov 26, 2006 01:19 AM
