95 to 69 engine swap
Old Aug 1, 2007 | 10:52 PM
mike mac's Avatar
mike mac
I just swappd a "95 f150 5.0 into my '69 bronco but have some tech q's. I installed the Holey pro injection so I just used the block and valves off the new motor, with no computer. However I would like to retain the serp. belt minus the a/c pump and air pump. Does anyone know if this is possible and if so what size belt and how do I connect the new alt. to old wirring?
Old Aug 2, 2007 | 09:43 AM
Kemicalburns's Avatar
Kemicalburns
i would post over in the early bronco forum.
Old Aug 2, 2007 | 11:37 AM
GRAVEYARDSHIFT's Avatar
GRAVEYARDSHIFT
Hi, I would use just a gm 1 wire alternator to keep it simple . I also would just use the belt setup off a 1990 -93 mustang 5.0 ,underdrive pulleys , as they make a air pump eliminator . Check E bay.http://cgi.ebay.com/ebaymotors/Ford-Racing-M-8604-A50-Air-Pump-Idler-Bracket-Mustang_W0QQcmdZViewItemQQcategoryZ46093QQihZ008QQ itemZ180139340750QQrdZ1QQsspagenameZWD1V The idler pullys should tell what belt to use.Pat
