transfer case
Old Aug 1, 2007 | 08:57 PM
prisoner of gravity's Avatar
prisoner of gravity
transfer case
off topic but it is driven by a 7.3...no replies over on the transmission forum...
truck is 2001 F250, OK in 4 hi and 4 lo but cannot shift into 2 hi, lever will not go forward into 2 hi position
any clues?
thanks
Old Aug 1, 2007 | 10:45 PM
catfish101's Avatar
catfish101
Check your linkage first. How long has the case been in 4x4? Did it just happen?
Old Aug 2, 2007 | 10:40 AM
prisoner of gravity
just happened, all was well before.
put it in 4 lo to pull the horse trailer across a muddy yard, then could not shift into 2 hi.
will look at linkage tonight, mama bear had to drive it to work this morning.
Old Aug 2, 2007 | 11:51 AM
vmac4's Avatar
vmac4
You may have the driveline in a bind.Try jacking up an axle or at least one wheel
to releave the tension,then try to shift into 2wd.When I attended the ford trasfer
case class,we drove a ranger in 4hi,around in circles until it quit moving completely.
Then we tried to shift into 2wd,would not shift.Jacked up one wheel,it spun around
and shifted into 2wd,no problem.
Old Aug 2, 2007 | 04:53 PM
dieself250's Avatar
dieself250
put the tranny in neutral,keep the brakes off and you should be able to shift back into 2hi....
Old Aug 2, 2007 | 07:43 PM
speedrdr's Avatar
speedrdr
does it have external locking hubs? i'm of the same opinion that the front driveshaft is in a bind. had same problem in '70 bronco and couldn't get it out of 4-low. 15 miles later, took wrenches and unbolted driveshaft and threw it in bed to get transfer case unlocked. my problem was the lockout hubs were trouble to unlock and wouldn't let the transfer case shift. might look at that.
speedrdr
Old Aug 2, 2007 | 11:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
That transfer case is 283, New Process is the manufacturer if I remember right.
That is what the 99+ trucks with the 4R100 and the ZF 6 trannies use.
My guess is the bushings in the shift lever or the actual linkage connections are getting worn.
Old Aug 3, 2007 | 09:09 PM
prisoner of gravity
thanks all
problem fixed...linkage was seized from sand, salt etc.
this is mama bear's truck so only gets occasional 4wd use in winter
it has Warn hubs.
downright luxurious compared to my 93 F350 ex-municipal crew cab.
thanks again,
