Lokar
Old Aug 1, 2007 | 08:44 PM
Woodsman_30350's Avatar
Woodsman_30350
Lokar
Has anyone used the Lokar accelerator pedal and if so, do you recommend the firwall or floor mount. Thanks,
Old Aug 1, 2007 | 09:06 PM
Showpanther's Avatar
Showpanther
I have the firewall mount for my 55 because of the linkage. I like the cable coming through the firewall in a straight line with the throttle verses the linkage doglegging up behind the motor.
Old Aug 2, 2007 | 12:15 AM
53fatfndr's Avatar
53fatfndr
I have the Lokar firewall mounted hot rod chrome "spoon" style pedal, real nice and simple to install.
Old Aug 2, 2007 | 07:10 AM
theGman's Avatar
theGman
i also used the firewall mount, for the simple straight line linkage.
Paul
Old Aug 2, 2007 | 07:41 AM
LEckart's Avatar
LEckart
I've used the Lokar Eliminator floor mount throttle pedal twice and it has worked fine both times. It is an easier install if you also purchase the carb bracket and cable from Lokar. Very clean with no linkage showing in the cab and only the cable on the firewall side. Also requires a rectangular hole to be cut, approx. 1/2" x 2" but it is covered when installed.
