Sunline TT Electrical Question
So, my 2000 T1950 Sunline Solaris has no power when not connected to Shore Power. My TowVehice is charging the TT Deep Cycle which shows a full charge. Every fuse (that I can find) appear good. When plugged in to shore power every single item works.
Thanks in advance.
I just got out from under the trailer tracing the + cable to where it goes inside. I was hoping for a fuse or fusible link. But no luck. The TT has been sitting for about 6 weeks since a 4k mile trip when everything worked fine.
I probed the + cable a few times working my way back from the battery. Has 12v all the way to where it goes through the floor. Inside, where it comes through, still 12v. At the front of the circuit board I have 12v at the 12v + post BUT only when shore power is plugged in. No shore power, no 12v at the front of the board. What confuses me is it comes directly to the 12v post from the 12v post of the battery.
The main circuit is working because when plugged into shore power and turn it off everything goes dead.
