Sponsored by: Real Truck
odd transmission question
Old Aug 1, 2007 | 04:29 PM
ayden2004's Avatar
ayden2004
Hey again, not a good sign with all this being Ive had the truck a month and a half. but I need to replace the release bearing in my truck. so I figure of course while im in there I should just replace clutch, pressure plate etc.... as well. but here is my problem. I have called around and have had a couple of garages tell me that they cant do it because I have the zf transmission. they say that thier transmission jacks cant handle it. I have access to a lift, transmission jack and a whole array of tools and have pretty good knowlege of vehicles. So I figured I would just do it all myself. but because of these garages argument I am worried that the jack I have won't work. does anyone out there know what the zf transmission in a '01 f250sd 5.4l v8 4x4 weighs. the jack says it can handle up to 1000lbs. so if anyone knows if it will work please let me know. thanks.
Old Aug 1, 2007 | 05:48 PM
ReAX's Avatar
ReAX
I find it hard to believe a manual weights more than 1/2 a ton, but I am not an expert. I imagine their problem is how to hold on to the transmission while it is on the jack, which case, you will need to build a cradle out of 2x4s.
Trans removal is one of the few jobs I prefer to do on the ground. I find it easier to control the trans and not have as far to fall. I have only done t-18's and it wasn't a bad job. However, the transfer case is usually a heavy mfer and I find it easier to pull the transfer case and then the transmission.
For clutch disk, pressure plate and throwout bearing, I liked my center force on my old truck. I used the dual friction pressure plate, the center force 1 disk and their standard bearing, to build a CF 2 setup.
