2002 5.4L Expedition wont start
Old 08-11-2007, 07:31 PM
MeDNKD's Avatar
MeDNKD
MeDNKD is offline
Exclamation 2002 5.4L Expedition wont start
I had my passenger side manifold bolts replaced yesterday. I drove home (nice and quiet ride). Later took it to the store. Then this am, went to start and the truck would not start. Fuel pump is making noise like it's cycling. I tried ether in the air intake, but just a slight firing with out starting. Has 120,000 miles and never had a problem starting. Any suggestions? Thanks!
Old 08-11-2007, 09:29 PM
bigblock_drock's Avatar
bigblock_drock
bigblock_drock is offline
welcome
could be a few things... try starting while giving some gas, if that helps then its the IAC vavle...
you say the fuel pumps working and slight firing maybe the injectors are bad...
thats all i can think of for now hopefully others will chime in and help.
Old 08-12-2007, 06:04 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Check all of your ground cables to make sure they are tight. A bad chassis ground can make the computer do strange things.
FutureFordTech
08-13-2016 10:13 PM
Pappys53
08-13-2015 09:16 PM
Loftatsea
07-31-2015 01:29 PM
longacre5
1997 - 2003 F150
01-19-2012 02:40 AM
h2oline
1978 - 1996 Big Bronco
12-02-2010 05:57 PM
Quick Reply: 2002 5.4L Expedition wont start
