replace clutch master cylinder
Old Jul 31, 2007 | 10:49 PM
modeltford's Avatar
modeltford
Hi!
I've searched the site for an answer to my problem, but can't find what I need! I have a 93 Ranger 4WD 4.0l 5speed. I replaced the clutch an slave cylinder, and while trying to bleed the system, I popped the piston out of the master. I got it back in, but now it leaks, so I got a new one. the question is - how do I get the D#$% thing out?? I can't get the push rod out of the master, I tried to pull the line off & found it has a drift pin holding it in - and NO room to remove it while it's in the truck! Do I need to remove the line at the bellhousing and pull the master, reservour,and line out as a unit??
Appreciate any help!
Rich
Old Aug 1, 2007 | 07:02 AM
Markga45's Avatar
Markga45
Hi Rich.
I think your truck would be basically the same as mine though mine is 2wd and yes, you have to pull the clutch master cylinder as a complete unit. The pushrod is not designed to come out of the cylinder so you have to take the line off (quick coupler) at the trans bell housing and remove the pushrod/cylinder/hose as an assembly. I think the reservoir hose that goes up to the little cup will slip right off so you don't have to deal with it being tangled in the mess.
Hope this helps.
Mark
Old Aug 1, 2007 | 01:03 PM
modeltford's Avatar
modeltford
Talking
Yes - it helps! Pretty much what was afraid of! Thanks for the help, Mark!
Rich
Knotwild
1997 - 2003 F150
Feb 25, 2011 05:30 PM
3006
Nov 17, 2010 11:03 PM
Neil_E.
Apr 12, 2009 11:45 AM
1989F250
Aug 16, 2004 05:10 AM
