Got my truck back yesterday...everything seems to be ok..the question i had is if the shift poiunts should feel any different at all after a rebuild?????
1st 2nd and 3rd feel normal but the shift into 4th seem to come later than it used to??? is this normal
The shifts are contoled by the ECM (computer) that doesent make sense? Shift points should be the same, have you put a programer/chip anything in your truck, that would make sense! I would be taking it back!
Rich
