problem with injector not firing
Old Jul 30, 2007 | 11:35 AM
holiday187's Avatar
holiday187
I was told atthe dealer that one of the injectors in this engine will not fire because vibration will cause the wire to one of the injectors to rub agianst something else and cause a misfire. but the truck will run fine once it's warmed up and running.
this is causing the trufckt to be hard to start. like i said once started it's fine. they said there's a ford fix were you put a rubber grommet around the wire. anyone know of this.
Old Jul 30, 2007 | 11:58 AM
8tsixt's Avatar
8tsixt
i know there is an updated harness. there are some writeups on it.
Old Jul 30, 2007 | 12:09 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Never heard of the grommet but have a look at post 1 here.
Old Jul 30, 2007 | 03:09 PM
clintbonnie's Avatar
clintbonnie
It might be just the under the valve cover pin connector (bad design). Mine was loose and ready to come apart with only 70k miles ... I just made a shim to keep the plastic locking tabs tight and it solved the problem.. You have to remove both valve covers to do this.. At the same time you can inspect your wire harness for rubbing, but mine was fine...Your profile says your truck is a 98..do you mean early 99?
Old Jul 30, 2007 | 06:59 PM
holiday187's Avatar
holiday187
nah this is for a truck at work.
j1msevier
Mar 6, 2013 06:14 PM
Hank85713
1983 - 2012 Ranger & B-Series
Jun 13, 2012 04:53 AM
ColoradoFordBoys
20
Jun 19, 2011 01:01 PM
wheelie31
Nov 6, 2010 09:46 PM
big315
24
Nov 30, 2007 08:21 PM
