I have a 90 Ranger 2wdr Custom with a 4.0/AOD. The other day while driving the trans suddenly started to slip and jump in and out of gears. When checking the oil I found it was empty. Added a couple of quarts and started the engine only to find oil pouring from between the engine and transmission. Since used parts are hard to get over here in Sweden I was wondering if any other AOD transmission from other Fords fits? Is there a difference in 2wdr and 4wdr trans? 4wdr transmissions are availabe here but haven't found any 2wdr. Or could it just be the input shaft seal that's gone bad?
Thanks,
Mats
If you don't get a reply here, try the transmission or engine forums, bet those guys would know, or would have a good idea where you could get accurate input.
