Blown head gasket, or block?
Old Jul 29, 2007 | 01:11 PM
rootbeerford's Avatar
rootbeerford
Well, my oil has water in it, I noticed this after the engine started overheating the other day, so what are the chances this is a blown head gasket? has anyone ever cracked one of these blocks? I have not towed anything since I got the truck about 5 months ago, the truck has seen only normal daily driving. Also why did my engine overheat, was it because all the bearings were not being lubricated, and are now possibly damaged. thanks for any help.
Old Jul 29, 2007 | 01:56 PM
tjc transport's Avatar
tjc transport
i ain't rite
before you give up on the engine, do a pressure test on it to see if you can pinpoint the leak source.
a common place for water intrusion into the oil system is the oil cooler.
Old Jul 29, 2007 | 02:11 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Do you also see oil in the water?
Old Jul 29, 2007 | 02:15 PM
PLC7.3's Avatar
PLC7.3
Cavitation will also dump water in the oil, but don't jump off the bridge yet. There are other areas too. If water is in the oil it is not in the rad so overheating would be likely a result. Done any water pump changes..... one not so common area is the head.. where the steel ***** are wedged into the cooling system to plug it next to the intake holes. They can rust and send coolant into the area under the valley pan. A compression test would give you heads up on cylinder problems. Cracked head, cavitation maybe, head gasket...
Old Jul 30, 2007 | 01:16 AM
rootbeerford
Dave, Ill check again but no oil in the radiator. drained the entire colling system and put a new radiator in just before this happened (overheating the first time caused the 20 year old abused radiator to give up), and there was nothing then I know. didnt check the oil the first time though because the oil pressure guage stayed in the same place it always is the whole time this was all going on, so I figured it was just the old radiator causing it to overheat.
