General Automotive Discussion
Dodge electrical question
Old Jul 28, 2007 | 09:36 PM
78stepside429's Avatar
78stepside429
I know its not a Ford, but its a good work truck! I have an 89 Dakota and I have a funky problem with my driver side tail light. When I have the lights on, it is lit, but when I apply the brakes, the light goes out. When the lights are off, the brake light lights up when I hit the brakes. The turn signal doesnt blink, so I have to do it manually, but if I have the brakes on, it barely does anything. When it rains, everything works fine. I have noticed that the flashing speed varies after it starts to dry, and then it does back to not flashing. I thought maybe it was the ground, but I ran a new ground wire from the light and grounded it to clean metal on the frame, but nothing has changed. This is very frustrating! I have to drive this in the city, so I dont want to get hit because someone couldnt see my directional. Can anyone give me some advice/help??? Thanks much.
Mike
Old Jul 28, 2007 | 11:48 PM
fellro86's Avatar
fellro86
sounds along the lines of a bad switch...
Old Jul 29, 2007 | 12:06 AM
ford2go's Avatar
ford2go
It might be the socket itself. If the ground in the socket (contact between socket and light) isn't very good, your external ground won't help.
ford2go
Old Jul 29, 2007 | 12:53 AM
pfogle's Avatar
pfogle
I'd start with a new bulb, then a new socket. Then make sure you have a good ground under the hood. There are a LOT of things an electrical gremlin could be.
Old Jul 29, 2007 | 02:33 AM
78stepside429
Well guys, the bulb is new and it still does it. The socket is a good possibility since it works when it gets wet. I should be able to go to the parts store and get a new one. The wiring actually looks to be in decent shape, but I know shorts can happen anywhere. Its the damnedest thing, its a champ when its wet, but as it dries, it gets choppy so to speak. I have watched the bulb flicker as I was testing it and it goes from bright to dim so I am really leaning towards a ground somewhere. Anyone else have any input?
Old Jul 29, 2007 | 10:31 AM
78stepside429
Well, I replaced the socket and the flasher and low and behold, its like I have a new truck. Thanks everyone for the help. You guys are much better than the Dodge forum I tried!
Mike
