So today I decided to be proactive and bleed the brakes on our truck. 95 F-150, 160k. Probably never been bled before.
3/8" flare nut wrench, some PB Blaster, and the right/rear bleeder screw STILL rounded off. Yeah, I'm really pissed. Either those things are corroded in there, or some 2-bit wrench monkey really overtightened it.
How can I remove this? The shape of the metal around the screw makes it hard to get anything on it, and there's only 3-4" of space between the brake and the frame.
It would seem that to remove the drum so I can get good access to it, I'd need to remove the diff cover, pull the c-clip, remove the wheel, pull the half-axle, and unbolt the shoe assembly from the axle.
Dave
Bleh. Not what I wanted to hear. This truck has a lot of underbody corrosion, so I'm sure that these brake parts are really nasty. I'm definitely going to avoid that job.
The front screws don't want to loosen either. I gave up.
Fortunately the brakes are fine, and I was only doing this to keep clean fluid in there.
Thanks for your help today.
Dave
Wheel cylinder sounds like an expensive part.... just listen to that word. Haha. I thought so, until I bought all new ones, and realized afterwards that I wouldn't have to eat Ramen noodles for the rest of the week.
I've never serviced or priced a wheel cylinder before. I could only see the large bracket that the bleeder threads into (the drum frame?) that looks like a bear to remove.
Now I'm looking at the manuals. I take from your comments that the bleeder is threaded into the cylinder, which isn't all that hard to get to. From the inside of the wheel I can't tell what it's threaded into. I'm still too lazy to screw with it now, but if there is a problem, I can handle it.
**First heat 'em up a bit and soak 'em overnight with PB Blaster or whatever pen oil you like then...***
Can you get at the bleeders with a socket? On my 91 F150 I had to replace darn near all the brake lines, and the rear bleeders were actually the easier of the bunch to get off.. I hammered on a socket that was just a bit smaller than 3/8. Might have been a 9/32 or 11/32 or a metric and got them off. Depends on how rounded, and I probably just got lucky, although there was a good deal of crust underbody.
The fronts? After wasting way too much time on the first one I just went ahead and pulled the wheels (battle unto itself) and replaced the calipers, and before assembly put a little dab of anti seize on the new bleeders and put them back in. Just on the threads so as not to contaminate the fluid.
BTW Calipers cost between $25 and $33 here for single-piston remans
