transmission fluid aod
Old Jul 28, 2007 | 10:28 AM
HENDEL's Avatar
HENDEL
90 ford e-150 van 5.0 302
can anybody tell me how many quarts does it take it says in the book 12.3
i do not know if thats right or not but im not sure
Old Jul 28, 2007 | 10:55 AM
94van's Avatar
94van
If you drain the torque converter, thats about right.
Old Jul 28, 2007 | 12:49 PM
HENDEL's Avatar
HENDEL
[QUOTE=94van]If you drain the torque converter, thats about right.[/QUOTE
how can you tell if the fluid is dirty and filter
i never changed a automatic trans this my first time in doing it
i never drove automatics trans]
i am uesto driving stick
Old Jul 28, 2007 | 01:12 PM
jroehl's Avatar
jroehl
The fluid should be a bright pink/red when you wipe it on a white paper towel. It should not be brownish or smell burnt. To completely fill an auto tranny, put in about 80-90% of the recommended amount of fluid, start it up, keep your foot on the brake and flop between D and R several times to work out the air. Then check the the fluid and top off...then go back to the "flop" some more...check the fluid again...rinse, repeat....
Jason
Old Aug 2, 2007 | 12:48 PM
Frat-man-du's Avatar
Frat-man-du
my 94 takes just over 12 so that seems right. I switched to Mercon V when i changed.
