Engine Lite On 4.2
Old Jul 28, 2007 | 07:30 AM
madcapper's Avatar
madcapper
Engine Lite On 4.2
99 E-150 engine lite on. Auto Zone code checker says Misfire Cyl 3.
New wires, new plugs, new coil.............
Where do I go from here ????????
By the way, THANKS to all who helped me solve my other problem. It was a broken valve sping No. 2..................No need for a rebuilt engine.
Old Jul 30, 2007 | 12:44 PM
bokker's Avatar
bokker
hi, how well does your engine run and can you feel the misfire. could try a petrol addative to clean out the fuel injectors. also try pulling the no 3 plug and see if there is a good spark when you earth it out. make sure it is away from the fuel vapore coming out of the plug hole. then maybe a compression test on that cylinder. good luck bokker.
Old Jul 30, 2007 | 05:02 PM
madcapper's Avatar
madcapper
Quick backround ..........all of a sudden bang, it ran bad, took it too Ford, said new engine..I said no no no......I ran it for a year on 5 cyls.....medical reasons could not fix.....finally 1 month ago pulled valve cover and broken valce spring #2...that plug always fouled badly. New valve spring......runs one million times better. Now comes up misfire #5. I have run Seafoam through gas tank, vaccum brake hose, Has new plugs, wires, coil.
