Sponsored by: Real Truck
3-way upfitter switch
Old Jul 27, 2007 | 02:13 PM
Twin Tritons's Avatar
Twin Tritons
I have the upfitter switches in my 2006 F-350 already, but would like to replace two of them with 3-way switches that match the stock ones. I like to have on-off-on. Does anybody make these?
Old Jul 27, 2007 | 02:17 PM
redford's Avatar
redford
FTE Leadership Emeritus
When you say ON-OFF-ON, are you wanting a switch that has like 1 circuit with 2 ON positions, or 2 separate circuits with a middle off (like a turn signal switch)?
Old Jul 27, 2007 | 02:30 PM
Twin Tritons
I would like to wire the driving lights so that I can choose how they come on.
Say when the switch is in the top on position the power will be on not matter what, when the switch is in the middle off position the power will be off, and when it is in the lower on position I will have it wired to a relay that only allows the lights to be on with the high beams.
I've done this with other trucks and it makes it nice. Driving down the highway with high beams and driving lights when a car comes around the corner, simply switch off highbeams and the driving lights turn off also. The manual on position is nice so I can use driving lights to cut through the ice fog we have in Alaska when I use low beams. High beams project too high and refract off the fog/snow/dust/etc...
Old Jul 27, 2007 | 02:48 PM
Beerstalker's Avatar
Beerstalker
Dont' think you will be able to find a replacement SPDT switch to switch out the factory switch for. You coult accomplish the same thing using two switches and a diode, if you have two switches to spare. If not you will probably have to get an aftermarket SPDT switch and find a place to mount it.
Old Dec 1, 2018 | 04:41 AM
Dirthikerida's Avatar
Dirthikerida
I was wondering if you ever found a 3way swich that fits in stock housing
Piolet
Sep 27, 2022 07:59 PM
Bigdon68
Sep 14, 2016 08:52 AM
TFLT
Jan 8, 2016 02:18 PM
andyak
Electrical Systems/Wiring
Aug 21, 2015 08:57 PM
jeffdoerr
Jul 22, 2009 08:59 PM
