I could've sworn LMC carried these...but cannot find it in their latest catalog? It's the boot that seals the clutch rod hole....anyone know where I can get one?
1965/67 F100/350
D2TZ-7A533-A .. Clutch Pedal Rod Seal 3 3/4"-long / 2 1/2" at flange.
Ford shows a different part number for 1968/71, but no measurements (D2TZ-B), and another (again, no measurements) for 1972 (D2TZ-C). This part isn't the same as the passenger cars use, it's truck only.
Do either of you know if a '72 boot sill work on a '67? I gotta stop all the header heat from pouring into the cab!!!
1972: Same firewall as 1967, same diameter (3/8") clutch rod as 1967 (tho a different rod). Ford changes part numbers almost as fast as women change their minds. I'd say it prolly will work.
