Carb Tuning questions
Old Dec 8, 2000 | 08:07 PM
billyb's Avatar
billyb
Old Dec 21, 2000 | 05:01 PM
bucket's Avatar
bucket
I just rebuilt my 400 in my '79 bronco. I have the Edelbrock Performer intake and a Carter 625 cfm carb. The truck starts up and idles perfectly, but has a hesitation / stumble off idle, leaving from a stop. The guy who rebuilt it is ordering a kit from Carter that has different jets and rods. He believes going up 1-2 jet sizes will improve the off-idle problem.
What do you guys think?
Thanks,
Bucket
'79 Bronco XLT
406 / C6 / NP205 / Bulletproof!
Old Dec 21, 2000 | 05:45 PM
jbhf250's Avatar
jbhf250
Could be the thing to do. It sure won`t take long to find out, and even go higher if need be. Carter/edlebrock carbs are very easy to work on. Maby the accererator pump setting is not good. If you have the tuneup guide that comes with new carbs it is very easy to get it right.
Some times going smaller on the jets is the thing to do also, just depends. Have a look at the plugs after driving for a while. They will let you get it right.
Don`t forget to have a good advance curv going for you also!!
__JOHN__Õ¿ö
Member-
"Crusin North" Car Club
Santa Rosa, Calif.
72 F-250
ICQ#6030753
Old Dec 30, 2000 | 09:53 PM
mavman's Avatar
mavman
mmm..sounds like what happened to my 514 in my 83. The 750 edelbrock works basically the same way as the carter, and a richer metering rod/jet combination should take care of it. Just read the manual that comes with the carb to help with selection.
Old Jan 4, 2001 | 03:32 PM
dre's Avatar
dre
A couple more things that will cause off idle stumble are
retarded Ignition Timing, Carb. Float Level, Accelerator pump.
