lifting blocks?
Old Jul 27, 2007 | 12:25 AM
stroken's Avatar
stroken
lifting blocks?
I have a 2003 crew cab long bed psd..It has a procomp 6.5" lift..Can i add bigger BLOCKS to that to make it sit higher? like will it work..and not fall apart or somthing? I want to lift it a little higher w/o buying a new 1500 lift...I seen 5" blocks and the ones now i think are 2 or 3 so I was just wondering..and now can that same thing be done to the front and back? thanks alot guys
Old Jul 27, 2007 | 12:51 AM
deemac's Avatar
deemac
pro comp has a hanger kit available to give you another couple of inches
Old Jul 27, 2007 | 12:53 AM
AustinS's Avatar
AustinS
You can replace the rear blocks and U-bolts. Don't stack another block on top of what is there. Remove the block you have in there and replace with a one piece block that's the height you want. Make sure you replace the u-bolts too.
On the front you have to do new springs, add a leafs, or spring hangers to get extra height. Under no circumstance do you ever block the front.
Austin
