Check engine light on
Old Jul 26, 2007 | 11:07 AM
mtr999's Avatar
mtr999
Does anyone have idea what is with it check engine light keep poping on and off, oil pressure is fine, engine cool normal, battery is normal, everything runs like champ but the checkengine light keeps popping on and off. It is 4.9L, 300-6, '95 f 150. I have water pump and tuned up with platinum plugs done in Dec '06 and the problem is since then. Everything runs like champ. Any idea?
Old Jul 26, 2007 | 11:10 AM
Blurry94's Avatar
Blurry94
Some auto parts stores, like Auto Zone or Advanced, will scan it for free. You can also buy a 20 dollar scan tool or use the 'ol DIY method: http://www.fordfuelinjection.com/?p=13
Old Jul 26, 2007 | 11:31 AM
mtr999's Avatar
mtr999
Also is the engine supposed to get hot real quick like temp gauge going up if you use AC (turned to 2) and the truck is not moving but let say idling at parking lot or busy intersection for like 4-5 min? Once truck start moving the temp gauge start coming down...it only happens every time we at 88-93 degree day time driving, if the AC is not on, the temp gauge never goes up, it is like solid on the cold side. Thanks
Old Jul 26, 2007 | 12:35 PM
Wingman69's Avatar
Wingman69
Originally Posted by mtr999
.. tuned up with platinum plugs done in Dec '06 and the problem is since then. ...
I was under the impression not to use platinum plugs. Everyone I've ever talked to says the trucks are picky and to use Motorcraft plugs.
Old Jul 26, 2007 | 12:54 PM
Blurry94's Avatar
Blurry94
It's normal for the engine to run a little warmer in the summer time, especially when it's idling and the A/C is on. The condenser is mounted next to the radiator so the radiator is going to soak up some of that when you're not moving.
offroad_4life
Apr 24, 2014 06:54 PM
2006 F250
Jun 3, 2012 11:53 AM
s0ckm0nky
Apr 1, 2012 08:04 PM
NewEnglander
Mar 23, 2012 06:59 PM
trakman
Modular V10 (6.8l)
May 30, 2004 07:09 PM
